CPU Utilization Trend Report
1665     0
<form>
  <label>CPU Utilization Trend</label>
    <input type="time" token="time" searchWhenChanged="false">
      <label>Time</label>
      <default>
        <earliest>-1d</earliest>
        <latest>now</latest>
      </default>
    </input>
    <input type="dropdown" token="topn" searchWhenChanged="false">
      <label>Top N</label>
      <default>5</default>
      <prefix>top</prefix>
      <choice value="5">5</choice>
    </input>
    <input type="multiselect" token="members" searchWhenChanged="false">
      <label>Members</label>
      <search>
        <query>index=ib_system_summary report=si_cpu_usage
      </search>
      <default>*</default>
      <prefix>(</prefix>
      <suffix>)</suffix>
      <valueSuffix>"</valueSuffix>
      <delimiter> OR </delimiter>
    </input>
    <input type="dropdown" token="ea_site">
      <label>Member Site</label>
      <default>All</default>
      <search>
        <query>| inputlookup __grouping_by_ea_tag_lookup
               | spath input=EA path=Site output=EA_Site
               | stats count by EA_Site </query>
      </search>
      <fieldForLabel>EA_Site</fieldForLabel>
      <fieldForValue>EA_Site</fieldForValue>
      <change>
        <condition value="All">
          <set token="ea_site_str"> | noop </set>
        </condition>
        <condition value="*">
          <set token="ea_site_str"> | spath input=EA path=Site output=EA_Site
                                    | where EA_Site="$value$"</set>
        </condition>
      </change>
    </input>
    <input type="radio" token="group_by">
      <label>Group By EA Tag/Field</label>
      <choice value="none">None</choice>
      <choice value="EA_Site">Site</choice>
      <default>none</default>
      <change>
        <condition value="none">
          <set token="group_by_str"> | noop </set>
          <set token="group_by_stats"> | noop </set>
          <set token="time_chart_field">orig_host</set>
          <unset token="show_calculation" />
          <set token="calculation_method">avg</set>
          <unset token="form.calculation_method"></unset>
        </condition>
        <condition value="EA_Site">
          <set token="group_by_str">| spath input=EA path=Site output=EA_Site
                                    | eval EA_Site = if(isnull(EA_Site),"(No_Value)",EA_Site)</set>
          <set token="group_by_stats">  | stats avg(CPU_PERCENT) as CPU_PERCENT by _time, orig_host, EA_Site </set>
          <set token="time_chart_field">EA_Site</set>
          <set token="show_calculation">true</set>
        </condition>
      </change>
    </input>
    <input type="radio" token="calculation_method" depends="$show_calculation$">
      <label>Calculation method</label>
      <choice value="sum">Aggregate</choice>
      <choice value="avg">Average</choice>
      <choice value="max">Maximum</choice>
      <default>avg</default>
    </input>
      <label>View</label>
      <choice value="chart">Line Chart</choice>
      <choice value="table">Table</choice>
      <default>chart</default>
      <change>
        <condition value="table">
          <set token="show_table">true</set>
          <unset token="show_chart"></unset>
        </condition>
        <condition value="chart">
          <set token="show_chart">true</set>
          <unset token="show_table"></unset>
        </condition>
        <condition value="both">
        </condition>
      </change>
    </input>
  </fieldset>
  <search id="base_search">
           $members$
           $ea_site_str$
           $group_by_str$
           $group_by_stats$
           | timechart bins=1000 $calculation_method$(CPU_PERCENT) by $time_chart_field$ where max in $topn$  useother=f
           | interpolate 1200</query>
  </search>
  <row>
    <panel isVisible="$show_chart$">
      <chart depends="$show_chart$">
        <search base="base_search">
          <query>| rename _time as Time
                 | eval Time=strftime(Time, "%Y-%m-%d %H:%M:%S %Z")
          </query>
        </search>
        <option name="charting.axisTitleX.text">Time</option>
        <option name="charting.axisTitleY.text">Utilization (%)</option>
        <option name="charting.axisY">numeric</option>
        <option name="charting.axisY.minimumNumber">0</option>
        <option name="charting.axisY.maximumNumber">100</option>
      </chart>
    </panel>
  </row>
  <row>
    <panel isVisible="$show_table$">
      <table depends="$show_table$">
          <query>| sort -_time
                 | eval Time=strftime(Time, "%Y-%m-%d %H:%M:%S %Z")</query>
        </search>
      </table>
    </panel>
  </row>
</form>
