DDNS failure report
6811     0
Looking for a report that shows DDNS failures, must include the following data:
IP of client
FQDN (of attempted update)
Error
Zone
this info seems to be in the syslog, but I cant get a report to work.
sample syslog entry (IP, zone, and update changed for security):
client 1.1.1.1#36540/key dhcp_updater_default: updating zone 'zone.com/IN': update unsuccessful: ddnsupdate.zone.com/TXT: 'RRset exists (value dependent)' prerequisite not satisfied (NXRRSET)
Re: DDNS failure report
6812     0
Steve,
I assume you are doing this with 7.3.200, since that is the only version which currently supports syslog data in the reporter?
If so, you'll need to create the necessary extractions, then generate the report.
-Roger
6812     0
index=ib_syslog dhcp_updater_default | rex "client (?<Client>[^#]+).+zone '(?<Zone>[^\/]+)\/IN'.+unsuccessful: (?<FQDN>[^:]+):.*\((?<Error>.+)\)" | stats count as Errors by Client Zone FQDN Error | sort -Errors
Vadim
