DNS Top Requested Domain Names with Filter
1417     0
This is a varation on the DNS Top Requested Domain Names default report which enables you to filter on domain name. Note that this report only gives a summarized count of requests for the given domain name. If you are looking for detailed information on the specific DNS queries you still need to use the Infoblox Data Collector and associated reports.
screencapture-demogm1-infoblox-ui-CYx4B5-WWI5gmxTi66uXTA-CYx21-mxT18-1484591779270.png
<form>
  <label>DNS Top Requested Domain Names with Filter</label>
  <description>DNS Top Requested Domain Names with a Filter to filter by domain</description>
      <label>Time</label>
      <default>
        <earliest>-1d</earliest>
        <latest>now</latest>
      </default>
    </input>
    <input type="text" token="domain_filter">
      <label>Domain Filter</label>
      <default>*</default>
    </input>
    <input type="dropdown" token="topn" searchWhenChanged="false">
      <label>Top N</label>
      <choice value="5">5</choice>
      <default>10</default>
    </input>
    <input type="multiselect" token="members" searchWhenChanged="false">
      <label>Members</label>
      <search>
        <query>index=ib_dns_summary report=si_dns_requested_domain
      </search>
      <prefix>(</prefix>
      <suffix>)</suffix>
      <valueSuffix>"</valueSuffix>
      <delimiter> OR </delimiter>
    </input>
    <input type="text" token="tld">
      <label>TLD</label>
      <default>All</default>
      <change>
        <condition value="All">
          <set token="tld_str">*</set>
        </condition>
        <condition value="*">
          <set token="tld_str">TLD="$value$"</set>
        </condition>
      </change>
    </input>
    <input type="dropdown" token="dns_view">
      <label>DNS View</label>
      <search>
               | stats count by display_name</query>
      </search>
      <fieldForLabel>display_name</fieldForLabel>
      <fieldForValue>display_name</fieldForValue>
      <change>
          <set token="dns_view_str">*</set>
        </condition>
          <set token="dns_view_str">display_name="$value$"</set>
        </condition>
      </change>
    </input>
      <label>View</label>
      <choice value="chart">Bar Chart</choice>
      <choice value="table">Table</choice>
      <default>chart</default>
      <change>
        <condition value="table">
          <set token="show_table">true</set>
          <unset token="show_chart"></unset>
        </condition>
        <condition value="chart">
          <set token="show_chart">true</set>
          <unset token="show_table"></unset>
        </condition>
        <condition value="both">
        </condition>
      </change>
    </input>
  </fieldset>
  <search id="base_search">
              $domain_filter$
              $members$
              $tld_str$
              $dns_view_str$
              | stats sum(COUNT) as FQDN_TOTAL by FQDN
              | sort -FQDN_TOTAL
              | head $topn$
              | eventstats sum(FQDN_TOTAL) as TOTAL
              | eval PERCENT=round(FQDN_TOTAL*100/TOTAL, 1)
              | eval PHOST=FQDN+" ("+PERCENT+"%)"
              | rename FQDN_TOTAL as Count, PHOST as "Domain Name"
              | fields "Domain Name", Count</query>
  </search>
  <row>
    <panel>
      <chart depends="$show_chart$">
        <search base="base_search">
          <query>| noop</query>
        </search>
        <option name="charting.chart">bar</option>
        <option name="charting.axisTitleX.text">Domain Name</option>
        <option name="charting.axisTitleY.text">Count</option>
      </chart>
    </panel>
  </row>
  <row>
    <panel>
      <table depends="$show_table$">
        </search>
      </table>
    </panel>
  </row>
</form>
