Data Connector Issue
- Email to a Friend
07-27-2018 01:28 PM
Hi All,
I have installed Data connector as per deployment guide. I'm sure there is no issue with configuration as i can see DC is registered with Grid and Reported status connected. DNS reporting properties is configured to log ib_dns_capture
But still i dont any report data realted to index=ib_dns_capture. It always get 'No results found.'
Any reason why above stats show all '0'.
Sachin
Solved! Go to Solution.
Re: Data Connector Issue
- Email to a Friend
07-31-2018 11:14 AM
Sachin,
What is the mode in the data.destination.reporting section? Is it set to forward? If not, then please set it to forward.
When in the data.destination section, what does the stats output show? Do you getting any non-zero numbers for pending files statistic?
On the grid side, navigate to grid --> reporting --> toolbar --> edit --> grid reporting properties. Click on DNS. Make sure you have monitoring queries disabled.
From your request, did you enable data indexing too?
Hope this helps.
Thomas
- Email to a Friend
08-16-2018 11:41 AM
Wouldn't you want the 'montior queries' enabled?
[ Edited ]- Mark as New
- Email to a Friend
08-16-2018 01:12 PM - edited 08-16-2018 01:13 PM
Steve,
I don't recall something called "Monitor queries" to be a requisite for this capturing queries & responses using the data connector. Did you mean "query monitoring" or "Monitor queries made to the following domains" ?
Either one of them are not required for setting up your DCVM. Does that address your question ?
Best regards,
Mohammed Alman.
- Email to a Friend
09-19-2018 04:03 AM
Thanks Thomas,
Issue was resoved after editing 'grid reporting properties'
Sachin
- Email to a Friend
11-12-2018 09:05 AM
Mohammed,
I was referring to Thomas's post of 'On the grid side, navigate to grid --> reporting --> toolbar --> edit --> grid reporting properties. Click on DNS. Make sure you have monitoring queries disabled.'
After playing around with the logging properties and the Reporting properties, I see the settings are different.
