How to best practise calculate total PC + Server use Reporting Infoblox
5506     0
Hi Guys,
Anyone know how to best practise to calculate total PC + Server use Reporting Infoblox ? Currently our project Infoblox in customer in phase migration from AD into Infoblox and then we got estimated total PC+ Server migrated to Infoblox  from our customer as below :
Domain :
supporting.corp.bankabcd.co.id with total PC + Server = 39.000
core-a.corp.bankabcd.co.id  with total PC + Server = 30.000
core-b.corp.bankabcd.co.id with  total PC + Server = 17.000
core-c.corp.bankabcd.co.id with total PC + Server = 44.300
etc
Currently we use methode calculate PC + Server as below :
Export from reporting  Infoblox and also copy manual to excel and we should take time to compare ( hour to hour / day to day ) the total PC+Server. How to best  practise calculate the total PC + Server have been migrate to Infoblox use Reporting  Infoblox ? Just info we use splunk for the software reporting
Thanks in advance,
Re: How to best practise calculate total PC + Server use Reporting Infoblox
5507     0
Hey there,
I don’t know if I understood your requirement correctly. But if you are trying to pull a stats of unique clients relying on your Infoblox DHCP server(So called the 'servers + pc migrated') & if your Infoblox DHCP server has been configured to send DHCP data to the Infoblox indexer, can you give this a try :
index=ib_dhcp_summary report=si_dhcp_top_os_by_network|bin _time span=1h|dedup MAC_DUID|eval FINGER_PRINT=if(isnull(OS_NUMBER) OR OS_NUMBER==0,FP,SFP)|eval DEVICE_CLASS=if(isnull(DEVICE_CLASS), "Unknown", DEVICE_CLASS)|stats count as FINGER_PRINT by DEVICE_CLASS|rename FINGER_PRINT as "Unique Hosts", DEVICE_CLASS as "Operating System"t=si_dhcp_top_os_by_network
The string pasted above is already a part of the default Home dashboard in Infoblox reporting & analytics app. I just pulled it out in specific & made a slight change. Let me know what additional piece is missing.
Best regards,
Mohammed Alman.
5507     0
Hi Mohammed Alman,
Thanks for your respond regarding my posting , this issue already solved after we communicate with our Internal team & consultant Infoblox.
Thank You,
