IPAM Discovered Device History by Network
3361     0
 This is a custom version of this dashboard. I've added networks filter. The query for the filter is not an optimal in terms of performance but anyway will work good for small IPAM databases.
<form>
  <label>pvm IPAM Discovered Device History</label>
  <fieldset submitButton="false" autoRun="true">
    <input type="time" token="field1">
      <label></label>
      <default>
        <earliest>0</earliest>
        <latest></latest>
      </default>
    </input>
    <input type="multiselect" token="networks" searchWhenChanged="true">
      <search>
        <query>index=ib_ipam sourcetype="ib:ipam:network" cidr<32 IPV4 | streamstats dc(_time) as distinct_times | head (distinct_times == 1) | dedup NETWORK</query>
      </search>
      <fieldForLabel>NETWORK</fieldForLabel>
      <fieldForValue>NETWORK</fieldForValue>
      <prefix>(</prefix>
      <suffix>)</suffix>
      <valuePrefix>cidrmatch("</valuePrefix>
      <valueSuffix>",IPADDR)</valueSuffix>
      <delimiter>OR</delimiter>
      <choice value="0.0.0.0/0">All</choice>
      <default>0.0.0.0/0</default>
      <initialValue>0.0.0.0/0</initialValue>
    </input>
  </fieldset>
  <row>
    <panel>
      <table>
        <search>
          <query>source=ib:discovery:ipaddr_activity index=ib_discovery | dedup IPADDR | where (IPADDR_MASK % 4) > 0 and $networks$ | sort 0 _time |lookup ipaddr_mask_lookup IPADDR_MASK output IPADDR_TYPE as Type | rename IPADDR as IP DISCOVERED_MAC_DUID as "Last MAC/DUID" DISCOVERED_NAME as "Device Name" DEVICE_TYPE as "Device Type" SHOWN_INTERFACE as "Port / Interface" NETWORK_VIEW as "Network View"  | table _time IP "Last MAC/DUID" Type "Device Name" "Device Type" "Port / Interface" "Network View"</query>
          <earliest>$field1.earliest$</earliest>
          <latest>$field1.latest$</latest>
        </search>
      </table>
    </panel>
  </row>
</form>
Vadim
Re: IPAM Discovered Device History by Network
3362     0
The same report for MAC addresses only.  You need to change the table's search string to:
| sort 0 _time | dedup DISCOVERED_MAC_DUID
| rename IPADDR as IP DISCOVERED_MAC_DUID as "Last MAC/DUID" DISCOVERED_NAME as "Device Name" DEVICE_TYPE as "Device Type" SHOWN_INTERFACE as "Port / Interface" NETWORK_VIEW as "Network View"  | table _time "Last MAC/DUID" Type "Device Name" "Device Type" "Port / Interface" "Network View"
Vadim
