Inactive MAC Addresses
4581     1
This report is a custom version of "Inactive IP Addresses" report and provide information about MAC addresses that were not connected to a network for a while.
<form>
  <label>pvm_Inactive MAC Addresses</label>
      <label>Time</label>
      <default>
        <earliest>-32d@d</earliest>
        <latest>now</latest>
      </default>
    </input>
    <input type="dropdown" token="network_view">
      <label>Network View</label>
      <search>
        <query>source=ib:discovery:ipaddr_activity index=ib_discovery
               | stats count by NETWORK_VIEW</query>
      </search>
      <fieldForLabel>NETWORK_VIEW</fieldForLabel>
      <fieldForValue>NETWORK_VIEW</fieldForValue>
      <change>
        <condition value="All">
          <set token="network_view_str"> </set>
        </condition>
        <condition value="*">
          <set token="network_view_str">NETWORK_VIEW="$value$"</set>
        </condition>
      </change>
      <default>All</default>
    </input>
    <input type="text" token="discovered_name">
      <label>Device Name</label>
      <change>
          <set token="discovered_name_str"> </set>
        </condition>
          <set token="discovered_name_str">DISCOVERED_NAME="$value$"</set>
        </condition>
      </change>
    </input>
  </fieldset>
  <row>
    <panel>
      <table>
        <search>
          <query>source=ib:discovery:ipaddr_activity index=ib_discovery             $network_view_str$             $discovered_name_str$             | where (IPADDR_MASK % 4) &gt; 0             | sort 0 _time             | streamstats current=false last(NON_NULL_PORT) as PREV_NON_NULL_PORT last(NON_NULL_NAME) as PREV_NON_NULL_NAME by IPADDR NETWORK_VIEW             | eval A2I=if((NON_NULL_PORT=="") AND ((PREV_NON_NULL_PORT!="") OR (isnull(PREV_NON_NULL_PORT)) OR (len(PREV_NON_NULL_PORT)==0)) AND (_time &lt; relative_time(now(), "-1w@d")), 1, 0)             | eval SHOWN_COMPONENT_NAME = if((NON_NULL_NAME=="") AND (PREV_NON_NULL_NAME!=""), PREV_NON_NULL_NAME, NON_NULL_NAME)             | eval SHOWN_COMPONENT_PORT = if((NON_NULL_PORT=="") AND (PREV_NON_NULL_PORT!=""), PREV_NON_NULL_PORT, NON_NULL_PORT)             | eval ACTIVE=if((NON_NULL_PORT!=""), 1, 0)             | where ((A2I==1) OR (ACTIVE==1))             | sort 0 -_time             | dedup DISCOVERED_MAC_DUID, NETWORK_VIEW              | where (A2I==1) AND (IN_USE_FLAG==1)             | eval SHOWN_INTERFACE = SHOWN_COMPONENT_NAME + if(len(SHOWN_COMPONENT_NAME)==0, SHOWN_COMPONENT_PORT, ": "+SHOWN_COMPONENT_PORT)             | rename DISCOVERED_MAC_DUID as "Last MAC/DUID" DISCOVERED_NAME as "Device Name" DEVICE_TYPE as "Device Type" SHOWN_INTERFACE as "Port / Interface" NETWORK_VIEW as "Network View"             | table "Last MAC/DUID" Type "Device Name" "Device Type" "Port / Interface" "Network View"  _time            | sort +ip(IP) +str("Network View")</query>
        </search>
      </table>
    </panel>
  </row>
</form>
Vadim
Re: Inactive MAC Addresses
4582     1
Vadim:  What is required or needs to be enabled to display Port / Interface column?  Is it simply just having Network InSight and the discovery enabled on the networks supporting these devices?  Or something else?   Reply appreciated.
4582     1
Vadim,
We tried using this @ a customer who is trying to clean up un-used MAC addresses that may not be in use.  We set the TIme interval to 1 year.  It produced many entries.  Doing a global search revealed a MAC was in use and discovered aproximately 1 month ago.  Why was this MAC listed in the "pvm_inactive_MAC_Addresses" report?
Reply appreciated.
Jimmy
