Last Queried output issue
- Email to a Friend
05-24-2017 12:18 PM
I tried Last queried command but instead of getting the amount of time each record is being queried i have either a 0 or empty field at the end....any idea why? and how could i fix this? thanks
#Get last_queried my $last_queried = $allrecord->last_queried();
view,zone,name,last_queried
cr_view,mnc***.*****.3gppnetwork.org,,
cr_view,mnc***.mcc***.3gppnetwork.org,,
cr_view,mnc***.mcc***.3gppnetwork.org,*.***.***.**.11.apn.epc,
cr_view,mnc***.mcc***.3gppnetwork.org,*.***.***l.**.1501.apn.epc,0
Solved! Go to Solution.
Re: Last Queried output issue
- Email to a Friend
05-24-2017 01:46 PM
Where are you running this command and getting the output from? This doesn't appear to be specifically related to the reporting server.
-Roger
- Email to a Friend
05-25-2017 06:01 AM
Hi Roger
Answer to your question: this is using Perl script talking to infoblox API.
My question: How I'm I supposed to run the command to avoid the issue?
thanks
- Email to a Friend
05-30-2017 12:59 PM
Hi Hasagh,
The Perl API call that you use is the right one.
Two things to check:
1 - Is "Enabled last queried time monitoring for resource records" enabled in the DNS grid properties and / or DNS zone > DNS scavenging
2 - In the Data Management > DNS > Zones in the zone content, after editing column to add "Last queried", do you see the date?
Regards
Nicolas
- Email to a Friend
05-31-2017 06:43 AM
Hi Nicolas,
Thanks for the asnwer
regrading option 1: I dont have the scavenging feature (and i m using version 7.2 of Grid and wont upgrade for now to 7.3 while at same time i need my stats numbers now) and this is why i was looking for an alternative way to get my stats. I was told that 'last queried' would be my option and found out a way to run it throught PAPI (which i shared above with issue in the results).
Now for the option 2, i tried to edit column as you instructed but i could not find any culumn named 'last queried'.
so not sure now how i can proceed.
- Email to a Friend
05-31-2017 11:19 AM
Hello Hasagh,
In NIOS 7.2 the procedure to enable the last queried feature in reporting was different. Please find the procedure attached.
I have checked the PAPI documentation and the call was already available, it should be ok once enabled.
Regards
Nicolas
- Email to a Friend
05-31-2017 01:45 PM
You will find the grid properties in Grid > Grid Manager > Reporting > Services > Edit button (pencil)
- Email to a Friend
05-31-2017 07:31 PM
I could not find the Reporting tab you mentioned..I have only 3 Tabs: Vizualization, members, and services.
Maybe it is a paid feature not included on the licenses that i have?
- Email to a Friend
06-01-2017 01:08 PM
Yes a reporting member, physical or virtual, has to be joined to the grid.
You can deploy an evaluation version and contact your Sales Engineer to see if the free 500 MB version suit your needs or not.
- Email to a Friend
06-02-2017 06:58 AM
Ok I see.
Thanks a lot for the help, i will follow up with infoblox.
