Accepted Solution
Monitoring Computer
miguelorb
4153     0
Hi.
I have a one cuestion.. infoblox can monitoring cumputers? or just monitoring router, switch and servers?
Re: Monitoring Computer
4154     0
Infoblox Reporting & Analytics monitors Infoblox core network services (DNS, DHCP, & IPAM). It monitor's your network device (computers, mobile devices, etc) interaction with those services to give more visibility into the past, current, and future of those interactions.
More detail can be found at https://www.infoblox.com/products/network-services-dns-dhcp-ipam/reporting
miguelorb
4154     0
thanks for your post....
then how add computers to infoblox?..
infoblox just detected switches routers servers and ap's...
i dont found how add end host (computers, tablets, etc)
4154     0
You don't need to add computers per se. The IPAM discovery will discover IP addresses that are used by computers or personal devices, or the DHCP fingerprinting will discover what computers or devices are on the network. In terms of reporting on those devices, you can do things like:
  • Report on the OS mix in the network
  • View the lease history for a given device
  • View the device history for a given IP
  • See which users are using which devices (Identity Mapping)
ariachris56
4154     0
Will it work on my iMac? I bought it last week from reecoupons by using Free Online Coupons, I want this service on it, well plz let me know about it.
