No data in IB_IPAM Index
3705     0
Hi Team,
I need urgent support, On reporter since last few days we are unable receive any data in 'ib_ipamIndex. I dont see there is any license violation. Please help me how to troubleshoot this issue.
There is data under other index but not under ib_ipam. I have reboot master, member and reporter but didnt help. Under reporter services everything is GREEN.
Sachin
Re: No data in IB_IPAM Index
3706     0
Hello Sachin,
From your comments, it seems it was working before and stopped suddenly. Please check if you have made any changes in Infoblox Grid or the network components in the perimeter. I would recommend you to open a support case with support bundles from member and Indexer.
Syam.
3706     0
Thanks Syam ,
Two changes were done
1. We use csv to configure extensible attributes on networks
2. Configured external syslog on member, master n reporter
sachin
Sachin
Sent from mobile
3706     0
Also be sure the grid reporting properties didn't change for that index.
screencapture-demogm1-infoblox-ui-Pb92YRBo4O1oudFzWtumGw-Pb9b6-1oud6-1510777869174.png
