Report for all Ports in Err-Disabled mode
1538     0
 I've been trying to create a custom report that gets emailed to NetOps informing them of all interfaces in "err-disabled" mode. I've tried using Data Type "Issues" and "Interfaces" but can't find the correct field that "sees" "err-disabled". There is a job under Job Mgmt that runs every 24 hours that logs in and finds the err-disabled ports. I don't know if there is a way to convert that output into a report. I ran a test report against a device that has an "err-disabled" port that looked for everything. The results were very detailed but only listed the port as up/down and nothing was noted for "err-disable". Any help is greatly appreciated.
