Reporting Volume Usage Trend per Member Report
1272     1
<form>
  <label>Reporting Volume Usage Trend per Member</label>
      <label>Time</label>
      <default>
        <earliest>-1d</earliest>
        <latest>now</latest>
      </default>
    </input>
    <input type="dropdown" token="topn">
      <label>Top N</label>
      <default>5</default>
      <choice value="5">5</choice>
    </input>
      <label>View</label>
      <choice value="line_chart">Line Chart</choice>
      <choice value="stacked_area">Stacked Area</choice>
      <default>line_chart</default>
      <change>
        <condition value="stacked_area">
          <set token="show_stacked_area">true</set>
          <unset token="show_line_chart"></unset>
        </condition>
        <condition value="line_chart">
          <set token="show_line_chart">true</set>
          <unset token="show_stacked_area"></unset>
        </condition>
        <condition value="both">
        </condition>
      </change>
    </input>
  </fieldset>
  <search id="base_search">
    <query>source=* index=_internal group=per_host_thruput
        | bucket span=1m _time
        | stats sum(kb) as kb by _time, series
        | eval gb=(kb/1024/1024)
        | timechart avg(gb) by series where max in top$topn$ useother=f
        | interpolate 120</query>
  </search>
  <row>
    <panel isVisible="$show_line_chart$">
      <chart depends="$show_line_chart$">
        <search base="base_search">
          <query>| noop</query>
        </search>
        <option name="charting.axisTitleX.text">Time</option>
        <option name="charting.axisTitleY.text">Volume (GB)</option>
      </chart>
    </panel>
  </row>
  <row>
    <panel isVisible="$show_stacked_area$">
      <chart depends="$show_stacked_area$">
        </search>
        <option name="charting.chart">area</option>
        <option name="charting.chart.stackMode">stacked</option>
      </chart>
    </panel>
  </row>
</form>
