Reporting in 7.3
4422     0
I just updated the NIOS to version 7.3 and Im having trouble setting up a schedule report to be sent via SCP to my server.
Y already configured the SCP server but I cant find the option to schedule a report to be sent to it.
For example, before 7.3 I could send the report "DNS Replies Trend" to my server via SCP or FTP, but now i cannot find the option to schedule the report like that.
I would apreciate any help.
Regards
Re: Reporting in 7.3
4423     0
You need to save your report as an alert and set the alert trigger action to "File Transfer Action". Note that this has to be done from the search, and cannot be done from a dashboard. You can open the results of a dashboard in search by hovering over the dashboard output and clicking on the search glass that appears in the bottom left.
Search the NIOS Admin Guide for "File Transfer Action" for step by step instructions.
4423     0
Thanks alot!
