Reporting on concurrent recursive clients
4370     6
Since 7.3.200 & newer versions, it is possible to redirect member syslog to the reporting appliance.
The direct application for reporting on concurrent recursive clients
named syslog example:
2016-06-21 09:50:04 CEST,"daemon","INFO","named[1583]","Recursion client quota: used/max/soft-limit/s-over/hard-limit/h-over/low-pri = 0/4/0/0/1000/0/0"
1) Enable Syslog redirection & syslog index in reporting properties
2) Field extraction
Add a field extration for the sourcetype ib:syslog
Recursion\s+client\s+quota[^=\n]*=\s+(?P<used>\d+)/(?P<max>\d+)/(?P<soft_limit>\d+)/(?P<s_over>\d+)/(?P<hard_limit>\d+)/(?P<h_over>\d+)/(?P<low_pri>\d+)
3) Testing Field Extraction
index="ib_syslog" "Recursion client quota"
4) Statistics
index=ib_syslog "Recursion client quota" | timechart avg(used) as used ,avg(max) as max ,avg(soft_limit) as soft_limit ,avg(s_over) as s_over ,avg(hard_limit) as hard_limit ,avg(h_over) as h_over ,avg(low_pri) as low_pri
5) Graphing
Line
Re: Reporting on concurrent recursive clients
4371     6
Great stuff, I had to do this years ago with Cacti and BIND which called a script to execute "rndc status" every few minutes and pulled out the recursive client usage. This looks like a much better way to do it! :-)
Paul Roberts
PCN (UK) Ltd
