Reporting results from a summary page
2615     0
I cant imagine this is difficult.  I want to build a report that will print out every device that still has telnet open.  I can easily click Explorer, summaries, ports, telnet(23) but I would like to have that in a report form.
Thoughts?
Re: Reporting results from a summary page
2616     0
If you are talking NetMRI, not sure the data is in Reporting but you cal use the RESTful API
/api/3/device_ports/search?ExpectedService=telnet
Let me know if this helps
Sif
https://sifbaksh.com
