Top DNS Blacklist l Hits Report
2359     0
Hi Community,
     How could I create a new report for "Top DNS Blacklist hit" such as " Top DNS Firewall hit"?
Dicky
Re: Top DNS Blacklist l Hits Report
2360     0
Infoblox Reporting already provides you this information as a predefined report/dashboard. Could you please confirm if you are referring to ADP based security reports or RPZ based? Both should already be available predefined.
Please clarify what you mean by creating a new report. Additionally, I would suggest taking a look at both the reports as well as dashboards of the same for abilities of customizations such as applying filters.
Best Regards,
Bibin Thomas
