Top DNS Clients w/Hostname Report
3180     0
Here is a modified version of the 'Top DNS Clients' dashboard that includes the source client hostname (based on reverse DNS lookup) along with the client IP address.
<form>
  <label>DNS Top Clients (Host)</label>
      <label>Time</label>
      <default>
        <earliest>-1d</earliest>
        <latest>now</latest>
      </default>
    </input>
    <input type="dropdown" token="topn">
      <label>Top N</label>
      <default>10</default>
      <choice value="5">5</choice>
    </input>
      <label>Members</label>
      <search>
        <query>index=ib_dns_summary report=si_dns_top_clients
      </search>
      <default>*</default>
      <prefix>(</prefix>
      <suffix>)</suffix>
      <valueSuffix>"</valueSuffix>
      <delimiter> OR </delimiter>
    </input>
    <input type="dropdown" token="dns_view">
      <label>DNS View</label>
      <search>
               | stats count by display_name</query>
      </search>
      <fieldForLabel>display_name</fieldForLabel>
      <fieldForValue>display_name</fieldForValue>
      <default>All</default>
      <change>
        <condition value="All">
          <set token="dns_view_str">*</set>
        </condition>
        <condition value="*">
          <set token="dns_view_str">display_name="$value$"</set>
        </condition>
      </change>
    </input>
      <label>View</label>
      <choice value="chart">Bar Chart</choice>
      <choice value="table">Table</choice>
      <default>chart</default>
      <change>
        <condition value="table">
          <set token="show_table">true</set>
          <unset token="show_chart"></unset>
        </condition>
        <condition value="chart">
          <set token="show_chart">true</set>
          <unset token="show_table"></unset>
        </condition>
        <condition value="both">
        </condition>
      </change>
    </input>
  </fieldset>
  <search id="base_search">
           $members$
           $dns_view_str$
           | stats sum(COUNT) as CLIENT_QUERIES by CLIENT
           | sort -CLIENT_QUERIES
       | lookup dnslookup clientip as CLIENT OUTPUT clienthost as CLIENT_RESOLVED
      | fillnull value="" CLIENT_RESOLVED
      | eval newField= CLIENT." ".CLIENT_RESOLVED
      | rename newField as CLIENT
           | head $topn$
           | eventstats sum(CLIENT_QUERIES) as TOTAL
           | eval PERCENT=round(CLIENT_QUERIES*100/TOTAL,1)
           | eval PCLIENT=CLIENT+" ("+PERCENT+"%)"
           | rename PCLIENT as Client, CLIENT_QUERIES as Queries
           | fields Client, Queries</query>
  </search>
  <row>
    <panel isVisible="$show_chart$">
      <chart depends="$show_chart$">
        <search base="base_search">
          <query>| noop</query>
        </search>
        <option name="charting.chart">bar</option>
        <option name="charting.axisTitleX.text">Client</option>
        <option name="charting.axisTitleY.text">Queries</option>
      </chart>
    </panel>
  </row>
  <row>
    <panel isVisible="$show_table$">
      <table depends="$show_table$">
        </search>
      </table>
    </panel>
  </row>
</form>
Steve S.
