[Updated] Deployment guide for Reporting and Analytics
6177     0
Here is the updated deployment guide for Infoblox Reporting and Analytics.
https://www.infoblox.com/wp-content/uploads/infoblox-deployment-guide-implementing-infoblox-reportin...
Check out our new Tech docs website for latest documentation on Infoblox products.
Re: [Updated] Deployment guide for Reporting and Analytics
6178     0
I noticed that the new deployment guide still mentions the action:
Run a script: Invokes a specified script stored on the reporting appliance
As of 8.0.6 that is still not supported and I have an RFE open for it.   The last time I checked on the RFE it was not even under consideration.   Has that changed?   I have several uses for that functionality.
6178     0
There are no confirmed plans to change that option at this time, but there is an RFE "Under Consideration" which would impact it that is pending prioritization for a future release. I'm not sure if it's the same one you mentioned.
