create a report for switch port utiliztioin
4310     0
howdy,
 i am trying to create a report for switchport utilzation that is longer than the 24 hour ones we already have. i would like to see when a switch port was first seen as well as last seen/used and for how long it had been up/down.
i am new to netmri so please use small words LOL!
Re: create a report for switch port utiliztioin
4311     0
Hello There,
Can you please check the report ‘Link changes’ under UI -> Reports -> Report gallery -> ‘Switch port management’ to see if that helps ?
Best regards,
Mohammed Alman.
