infoblox 1050-a
2325     1
Hi, I need help, I have infoblox 1050-a, but it does not work, I have power and a source this works, but the motherboard does not give me the signal and the coollers do not work before I work, but I could not insert A new ip that was locked in an ip. I opened the lid and it happened that I did not call any more, could someone help me
Re: infoblox 1050-a
2326     1
Do you indend to use the 1050-a for reporting?I don't belive there are any current versions of NIOS that will support that model. Infoblox "-a" models went end of support in December of 2015.
-Roger
