Security
C# WAPI return_fields Problem
4978     0
Hello
I would like to see the extensible_attributes of a specific hostrecord.
Unfortunately i don't find a way to display them using C#.NET.
I try the following:
<code>
public DataSet GetAllHostRecords()
                string url = "https://%IPADDR%/wapi/v1.1/record:host?_return_type=xml-pretty";
                WebRequest request = WebRequest.Create(url);
                request.ContentType = "application/json";
                request.Method = "GET";
                request.Credentials = new NetworkCredential("%USER%", "%PASSWORD%");
                ServicePointManager.ServerCertificateValidationCallback = new System.Net.Security.RemoteCertificateValidationCallback(AcceptAllCertifications);
                WebResponse response = request.GetResponse();
                Stream stream = response.GetResponseStream();
                StreamReader sr = new StreamReader(stream);
                string Message = sr.ReadToEnd();
                sr.Close();
                string xmlData = Message;
                DataSet myDS = new DataSet();
                byte[] buffer = Encoding.UTF8.GetBytes(xmlData);
                using (MemoryStream mystream = new MemoryStream(buffer))
                    XmlReader reader = XmlReader.Create(mystream);
                    myDS.ReadXml(reader);
                return myDS;
</code>
I can Display all received objects in a datagridview. (No Problem so far).
I select one of the hosts in my gridview to display its settings with the following method:
(Example ReferenceID: record:host/ZG5zLmhvc3QkLm5vbl9ETlNfaG9zdF9yb290LmNvbS5ydWFnLnJpbnRyYS5jaDFzNTA0Mi1tMQ:hostname.domain/%20)
<code>
 public string GetHostByReference(string ReferenceID)
                string url = "https://%IPADDR%wapi/v1.0/" + ReferenceID;
                MessageBox.Show(Message);
                sr.Close();
                return Message;
</code>
That method returns the information like this:
    "_ref": "record:host/ZG5zLmhvc3QkLm5vbl9ETlNfaG9zdF9yb290LmNoMXMxMzA4:%HOSTNAM%/%20",
    "ipv4addrs": [
            "_ref": "record:host_ipv4addr/ZG5zL.......
            "configure_for_dhcp": false,
            "host": "%Hostname%",
            "ipv4addr": "%IPAddr%"
    "name": "%Hostname%",
    "view": " "
My Problem is now how do i display the extensible attributes for that host?
Thanks for your help
Re: C# WAPI return_fields
4979     0
Hi Mike,
You need to add -d _return_fields= (with the name of the EA fields you want returned) to the GET
Ken Crozier
Sn. Technical Marketing Engineer
4979     0
Hi
Thanks for your reply
I was able to read the comment of a host record with the _return_fields option as follows:
<code>
                string url = "https://%IPADDR%wapi/v1.0/" + ReferenceID + "?_return_fields=comment"
                sr.Close();
                return Message;
</code>
This now returns:
    "_ref": "record:host/ZG5zLmhvc3QkLm5vbl9ETlN........",
    "comment": "BlaBla"
Entering the name of an Extensible Attribute as Example "OS" which is in that case Linux is still failing.
I tried the following which was working with the comment
 string url = "https://%IPADDR%wapi/v1.0/" + ReferenceID + "?_return_fields=OS"
Setting Extensible Attributes using the WAPI?
4979     0
How does one set the Extensible Attributes using the WAPI ?  I've tried the following:
curl -k3 -u admin:admin -H "Content-Type: application/json"-X POST https://192.168.1.2/wapi/v1.2/network -d '{"comment": "Foo Network", "network": "192.168.10.0/24", "extensible_attributes": {"Site": "Chicago Office"} }'
which fails.  Simply removing the "extensible_attributes" stuff allows the network to be created, but I can't seem to set the "Site" field, which shows up in the Extensible Attributes section.  Any ideas?
you can't get individual EAs,
Community Manager
Community Manager
4979     0
you can't get individual EAs, you just have to return all of them:
_return_fields+=extattrs
the EA struct looks like this
Community Manager
Community Manager
4979     0
the EA struct looks like this :
   "extattrs": {
      "Site": { "value": "East" }
