DDNS with Infoblox DHCP and MS DNS
2628     0
I'm testing the DDNS procedure from Infoblox DHCP and MS DNS servers.
At the moment I want to test only one network with no security option.
I want the Infoblox will be able to create/modify both A record and PTR.
Then, from my understanding I have to perform these steps:
1) With client defualt option 12 (hostname)
     - From DHCP network "Enable DDNS update"
     - From DHCP network I had to specify the domain (option 15) in order to build the FQDN with hostname sent           by client
     - From configure DDNS (DDNS options) I'll configure the DNS UPDATES TO EXTERNAL ZONES with the           forward-zone I want to update.
     - FIRST Question : because I want to modify also the ptr record, Should I also add the reverse-mapping zone?
       if yes, is this the right format (example of /16 Network): 142.10.in-addr.arpa ?
     - Last think I had to do is modify the MS DNS in order to accept update from the member where the netowrk is         in charge
2) With FQDN  option 81
      - Clients must to sand DHCPDISCOVERY with option 81
      - From DHCP network "Enable Option 81 Support" with first option because I want DHCP server always                    updates DNS
      - SECOND Question: the "Zones to Update for Hosts Using DHCP FQDN Option" is used only for DDNS in          Grid?
      - I should use the same DNS UPDATES TO EXTERNAL ZONES used for the first case also if I use option 81?
Please, let me know if I'm working properly or if I forgot something.
Thank you,
Fabio Colombo
Re: DDNS with Infoblox DHCP and MS DNS
2629     0
is there anyone that can clarify my doubts?
Thank you,
Fabio Colombo
