Security
DHCP Order Ranges
969     0
Hello Is the following possible
Subnet with 2 dhcp ranges
1st dhcp range contains a mac filter  with specific dhcp options
2nd range has no mac filter and standard dhcp options
Will a client that asks for a dhcp address , that is not in the first range Mac Filter  pick up an address from the second range.
if the Order is set mac filter range first and other range second ?
cheers for any info
