Security
Accepted Solution
Delegation Issues with RPZ zones/rules
TPersson
6717     0
i've delegated permission for our support staff to create and delete on our local RPZ zones with Read/Write permissions on the RPZ rules and read for the RPZ zones
everything works just fine, but when they try to skip to next page on the web interface, it starts loading the next page and shows the new content but its all greyed out and with a loading progress bar and it keeps doing that.
when i do it with my grid admin permissions everything works.
does any know if this is a web interface bug or do i need to give the support staff more permissions like read permission on a certain global object?
i've tested it with multiple browsers, we are using the newest NIIOS version (the older versions of NIOS also have this problem).
Regards
Terje Persson | Technical University of Denmark
Re: Delegation Issues with RPZ zones/rules
rdaens
6718     0
This looks like a cosmetic GUI issue. When you have set R/W permissions on your local RPZ zones and you add or delete a zone inside the local feeds , the GUI should not keep showing the Loading progress bar.
As a workaround you could use the browser refresh page button.
Please contact Infoblox Support so they can review and further investigate.
TPersson
6718     0
Thanks  for the reply, as i suspected it looks like a gui issue but its nice to hear what other people think before making a support ticket.
i will contect our reseller about it, so they can make a support ticket on this.
Regards
