Edit to the DDI MIBs so they will correctly compile for monitoring in order products
1538     0
Hi All,
I thought I would post this solution in case other customers are having trouble compiling the DDI MIBs in their monitoring tools.  As you all know there are about 7 MIBs for the DDI product.  All of them but the IB-SMI-MIB need to be manually modified.
The problem was that all of the files contained IMPORTS sections that were already defined in the IB-SMI-MIB.  For example, here's the IMPORT from the IB-DHCPONE-MIB:
IMPORTS
   OBJECT-TYPE, NOTIFICATION-TYPE, MODULE-IDENTITY, enterprises
        FROM SNMPv2-SMI
   TEXTUAL-CONVENTION FROM SNMPv2-TC
   Counter64, Unsigned32 FROM SNMPv2-SMI
   Counter FROM RFC1155-SMI
   ibDHCPOne, IbString, IbIpAddr FROM IB-SMI-MIB;
All it needs is the last line
...since all of the rest was imported in the IB-SMI-MIB:
IMPORTS MODULE-IDENTITY, OBJECT-TYPE, enterprises
          FROM SNMPv2-SMI
        TEXTUAL-CONVENTION
          FROM SNMPv2-TC;
Hope this helps people.
Susan
