Topic Options
How to assign a router IP to a DHCP range using REST
Options
- Email to a Friend
03-18-2013 05:07 PM
Hi, I need to know how to assign a router IP to a DHCP range of the IPAM product. I am able to successfully set a range with this syntax: https://10.130.190.5/wapi/v1.0/range?start_addr=6.6.0.2&end_addr=6.6.0.6&network=6.6.0.0/29 ...To clarify, In the IPAM GUI once a IPAM range is created, and you go into the edit window, you can set the IP Address of the Router under the IPv4 DHCP Options selection. I want to be able to set this Router IP using the REST api. Please give an example of how to do this.
Well, this is an old question, but I'll answer it anyway...
Options
- Email to a Friend
12-03-2013 04:10 AM
I was looking for the same thing, and seeing nobody answered so far, I'll write down what I did.
First of all you need to post the parameters in the body of the request as a JSON object and set the content-type of the body to application/json.
The body should look something like this:
{"member": { "_struct":"dhcpmember","ipv4addr":"x.x.x.x", "name":"infoblox.localdomain"} ,
"start_addr":"x.x.x.x",
"end_addr":"x.x.x.x",
"server_association_type":"MEMBER",
"enable_ddns":true,
"use_enable_ddns":true,
"options":[
{ "name": "dhcp-lease-time", "use_option": true,"value": "6000", "vendor_class": "DHCP" },
{ "name": "routers", "use_option": true,"value": "x.x.x.x", "vendor_class": "DHCP" },
{ "name": "domain-name", "use_option": true,"value": "ictest.local", "vendor_class": "DHCP" },
{ "name": "ntp-servers","value": "x.x.x.x", "vendor_class": "DHCP" }
"use_options": true
Obviously, you'll have to replace the x.x.x.x with something meaningful and the options are just samples. The URL to call will then be
https://infoblox/wapi/v1.1/range
Hope this helps
Greg
