I have a problem when I try to migrate a configuration with "diw".
Not applicable
3035     0
Diw dont make the string migration
class"VLAN10"{
  match if substring(option agent.circuit-id, 22,2) = "10";
                log(debug, "******* CLIENTE VIENE  DE VLAN10 *******");
#        log(debug, substring(option agent.circuit-id,0,25));
class"VLAN11"{
  match if substring(option agent.circuit-id, 22,2) = "11";
                log(debug, "******* CLIENTE VIENE  DE VLAN11 *******");
How can I configure the string in Trinzic?
Re: I have a problem when I try to migrate a configuration with "diw".
3036     0
is it an option 82 enable ?
