Security
Infoblox Tips and Tricks - Creating Approval Workflows for Users with Taskbar Permissions
OZayas
4413     0
Do you want to expand the ability for other IT staff to add DNS or DHCP data but in a limited fashion?
Would you like their changes to go through an approval process first?
Then read this post on how to do just that!  This post will help you create a limited-access permissions group that solely has access to the IPAM Tasks sub-menu and uses the approval workflow for adding DNS or DHCP data via the IPAM Tasks wizards.
Click here to access document
Re: Infoblox Tips and Tricks - Creating Approval Workflows for Users with Taskbar Permissions
tsmith4usac
4414     0
The link in this article is not valid.  I believe the latest version of the document referenced can be found in this post:  https://community.infoblox.com/t5/DNS-DHCP-IPAM/Creating-Approval-Workflows-For-Users-with-TaskBar-P...
