BloxOne Threat Defense and Threat Intelligence
Infoblox security feeds and download module sets from manegement interface
5100     0
Hi All
Is it possible to have security feeds i.e. Active RPZ tunnel for DNS FW and Updates for Threat Insight to download from management interface of the Infoblox , as per my understanding the both uses the VIP on whcih the DNS service is running , please advise what config is required to have management interface to download this feeds ...only enabling the management inerface will this traffic go from management interface i..e feeds download from internet. ??
Re: Infoblox security feeds and download module sets from manegement interface
5101     0
@rameshwar wrote:
Hi All
If the MGMT port is enabled, NIOS will use its routing table to determine which interface should be used for communications. You can add a static route to help force this.
Tony
