[NetMRI] Could not evaluate rule logic
- Email to a Friend
05-29-2018 02:42 AM
I need your help for my appliance NetMRI in compliance.
I have a policy using the raw XML editor and I have deployed this policy for a group.
NetMRI using this policy for check the compliance of my devices on this group.
But, the result of check for certain devices finished with status UNKNOWN..
Error message : Could not evaluate rule logic: No running configuration is available for this device.
However, on device viewer -> Configuration management I have the configuration file !
And when I run the policy manually, with the same device, I have a good result of compliance (pass, error, warning, ...)
Thank you for you help.
Regards
Solved! Go to Solution.
Re: [NetMRI] Could not evaluate rule logic
- Email to a Friend
05-29-2018 12:02 PM
I had a similar symptom for which I still have an open case. One possible cauase was a race condition seen in 7.2.1 and 7.2.2 caused by a device becoming unlicensed and then quickly relicensed. There is a hotfix for that. But that was not my situation.
The cause of the "unknown", as listed in the PV detail was that the stored config was "out-of-date", even though SNMP polling (ccmHistory) showed that no changes had been made since the last stored revision.
- Email to a Friend
05-29-2018 12:03 PM
BTW, this topic really belongs in the Network Automation forum, not Security.
- Email to a Friend
05-29-2018 01:24 PM
- Email to a Friend
05-30-2018 09:43 AM
Thank you.
I have also the devices with error message :
Could not evaluate rule logic: The running configuration for device is out-of-date.
Last Retrieval Attempt: 2018-04-17 21:00:37 +0100, Last Successful Retrieval: , Running Config Last Change as reported by SNMP: 2018-03-20 19:01:20 +0100
- Email to a Friend
05-30-2018 10:27 AM
- Email to a Friend
06-01-2018 07:22 AM
Thank you.
Yes, I have the configs in the UI. But the same error message.
So, I have open a case for this issue.
Regards.
