Security
Problems with RPZ demo: NS db_find() failed: quota reached
JMurray
3719     0
We enabled RPZ in "LogOnly (Disabled)" mode at:
Mar 11 09:06:17 192.168.0.1 named[10152]: zone malware.rpz.infoblox.local/IN: Transfer started.
Before we enabled RPZ our Recursive Quota stats looked something like this:
Mar 11 09:05:16 192.168.0.1 named[21378]: Recursion client quota: used/max/soft-limit/s-over/hard-limit/h-over = 245/830/0/0/1000/0
Mar 11 09:06:09 192.168.0.1 named[21378]: Recursion client quota: used/max/soft-limit/s-over/hard-limit/h-over = 182/830/0/0/1000/0
After RPZ was running for a few minutes our Recursive Quota stats looked like this:
Mar 11 09:11:15 192.168.0.1 named[10152]: Recursion client quota: used/max/soft-limit/s-over/hard-limit/h-over = 1000/1000/0/0/1000/20171
Mar 11 09:16:22 192.168.0.1 named[10152]: Recursion client quota: used/max/soft-limit/s-over/hard-limit/h-over = 984/1000/0/0/1000/39953
Mar 11 09:21:22 192.168.0.1 named[10152]: Recursion client quota: used/max/soft-limit/s-over/hard-limit/h-over = 997/1000/0/0/1000/60788
Mar 11 09:26:22 192.168.0.1 named[10152]: Recursion client quota: used/max/soft-limit/s-over/hard-limit/h-over = 1000/1000/0/0/1000/83541
Yes, the 1000 in there means we maxed out the recursive name server and started dropping DNS queries, which are logged like this:
Mar 11 09:17:53 192.168.0.1 named[10152]: client 192.168.55.251#13374 (p52-buy.itunes.apple.com): rpz NSIP rewrite p52-buy.itunes-apple.com.akadns.net via p52-buy.itunes-apple.com.akadns.net unrecognized NS db_find() failed: quota reached
Support has asked us to bump up the max quota from 1000 to 2000 to solve the problem.  Has anyone else run into this issue when enabeling RPZ?
Re: Problems with RPZ demo: NS db_find() failed: quota reached
Simonau
3720     0
what NIOS ver you are using ?
TomNelson
3720     0
Did this get resolved?  I am seeing the following in our syslog after enabling RPZ feeds
Recursion client quota: used/max/soft-limit/s-over/hard-limit/h-over/low-pri = 1634/4000/3900/637344/4000/303514/1629
I currently have our IB 1410 recursive clients settting at 4000 and has been running fine.
Is this normal behavior to be that absurdly high after enabling RPZ feeds?
I am running NIOS 8.1.6
