Tuscany DNS Sync. Does it work with 6.8.2?
Not applicable
1342     0
We recently upgraded from the 6.3.8 code to the 6.8.2 code.  We also upgraded to a new grid master HA pair.  Since then we have been unable to sync using the DNS Sync tool as we have done for quite some time.
To troubleshoot I installed the DNS sync tool on our lab GM and was unable to login with the tool.  When I enter the credentials it returns me back to the login prompt or   There appears to be limited documentation for this.
Does anyone still use this or is the load balancer option the way to go?
