Security
URL redirection using DNS
3992     0
Is it possible using DDI to redirect a users dns query ?exampleam authoritive for domain abc.com ( this is setup on the infoblox )is it possible using cnames or any other way ?So when a user types in test.abc.com , the dns query response gives back test.123.com and the users browser is redirected.I can't just put in an A record saying test.abc.com points to 1.2.3.4 because this ip address changes so it needs to point to another name is this possible using Infoblox DNS , or am I barking up the wrong tree.Cheers for any info or tips.
Re: URL redirection using DNS
Employee
Employee
3993     0
If you're talking about a single test machine that might change once in a while, then youc ould do this via infoblox. use a short TTL so that when it changes the old value isn't cached long.
If it changes a lot, or is pointing to a collection of machines working in tandem, then this is more something for a proxy or a round robin setup, and you should look at those (and then point at it via infoblox)
