Security
Way to create bulk number of resource record
Employee
Employee
3034     0
Team, Kindly suggest me the way to create bulk number of ARECORDS all together than going GUI and adding one by one.Suggest me the alternative way to add resource record type ARECORDThanks..
Re: Way to create bulk number
3035     0
I'm not sure a link to the "Officially Unsupported" ibCli is allowed, but looks like this is what you need. It is a Perl based command line which interfaces with the Grid Master.
http://ibcli.blogspot.be/
There is a good amount of documentation on how to do bulk creations/imports. For your specific case it would look something like:
conf zone foo.com add a_record test1 1.1.1.1
conf zone foo.com add a_record test2 2.2.2.2
conf zone foo.com add a_record test3 3.3.3.3
Community Manager
Community Manager
3035     0
Create a 'Bulk Host' record. This will automatically generate hostnames and A records for the range of IP addresses that you've specified.
