Fully uninstall procedure to Infoblox Plugin for integration with vRA 7.3 + vRO 7.3
6373     0
Hey All,
Please advise if there is any fully uninstall procedure to Infoblox 4.3 plugin which integrated with vRA and vRO 7.3.
And all other settings to uninstall in order (endpoint, Network reservation, Property Group, etc...)
Thanks a lot,
Avner Vidal
Re: Fully uninstall procedure to Infoblox Plugin for integration with vRA 7.3 + vRO 7.3
Community Manager
Community Manager
6374     0
The instructions for removing the plugin can be found in the user guide that is included alongside the plugin installer.
Tony
6374     0
Thanks for your answer.
But it is not clear how to do that with vRO cluster if I need to perform the steps only on the first vRO or on both...
Please advise if you can.
Community Manager
Community Manager
6374     0
Nothing is really installed on the vRO side. The IPAM endpoint that points to Infoblox is stored in its cache so clearing that from the cache may be all that's needed with vRO, and that can be done with a simple restart.
Tony
6374     0
@TTiscareno wrote:
Nothing is really installed on the vRO side. The IPAM endpoint that points to Infoblox is stored in its cache so clearing that from the cache may be all that's needed with vRO, MyFedLoan Servicing and that can be done with a simple restart.
Tony
6374     0
To remove the Infoblox IPAM Plug-In for VMware from vRealize Orchestrator on Windows:
Log in to the vRealize Orchestrator Control Center web page. Click Plug-Ins –> Manage Plug-Ins. Deselect the Infoblox IPAM Plug-in check box and click Save changes.
Go back to the vRealize Orchestrator Control Center page.
Click Certificates. In the certificates list, click Delete for those which common name is
Open the Windows Services list and stop the following services:
VMware vRealize Orchestrator Configuration VMware vRealize Orchestrator Server Navigate to the installation directory of the vRealize Orchestrator server.
The default path is: C:\Program Files (x86)\VMware\vCAC\Server\ Remove the following files and directories from the vRO installation directory:
Infoblox_IPAM_Plugin.xml o11nplugin-ipam.dar o11nplugin-ipam-config.war o11nplugin-ipam-config directory In the installation directory of the vRealize Orchestrator server, open the file _VSOPluginInstallationVersion.xml for editing.
Remove the Infoblox IPAM Plug-In for VMware version data from the file by deleting all the lines that start with or .
Open the Windows Services list and start the following services:
VMware vRealize Orchestrator Configuration VMware vRealize Orchestrator Server Log in to the vRealize Orchestrator client. Select either Administer or Design mode.
Click the Packages tab.
Delete the vRA and IPAM packages of the Plug-in the following order:
Right-click com.infoblox.integrated.ipam and select Delete element with content. In the Delete confirmation window, click Keep shared. Repeat steps a and b for com.infoblox.ipam.
tellpopeyes
