Issue same ip address tail for multi interfaces in vRA/vRO 7.4
- Email to a Friend
09-18-2018 01:29 AM
Hi ,
We have multi interfaces on each vm connect to different segments , Can I issue the same address tail for those interfaces in vRA/vRO 7.4
Example:
Interface 1 -> 11.1.10.10
Interface 2 -> 11.1.20.10
Interface 3 -> 11.1.30.10
Re: Issue same ip address tail for multi interfaces in vRA/vRO 7.4
- Email to a Friend
09-18-2018 11:14 AM
I'm not sure I understand what you are asking here, but devices can have multiple IP addresses and NIOS will be able to track each of those separately in IPAM. DNS has no issue with multiple IP's under a single name.
Tony
[ Edited ]- Mark as New
- Email to a Friend
10-06-2018
04:55 AM
- last edited on
05-15-2019
06:53 AM
by
TTiscareno
hey there!!!
I am also facing this issue... The multiple interfaces in vRA/vRO are having problem of same ip issues. I tried to change ip addresses with changing the internet connections. But, still its not working! How to fix this issue???
Thanks
<Moderator> External link removed.
- Email to a Friend
05-15-2019
04:20 AM
- last edited on
05-15-2019
06:54 AM
by
TTiscareno
@Eli187 wrote:
hey there!!!
Thanks
- Email to a Friend
01-24-2020 11:00 PM
vRealize Orchestrator Appliance on the same IP address and FQDN.
- Email to a Friend
You cannot use the same IP address on multiple interfaces. It just won't work properly (usually it will only work on the last interface the IP was assigned on). You need to put the ethernet interfaces into a bridge and assign the IP address on the bridge itself.
- Email to a Friend
Add routing tables and rules binding source IP address for each route, and add those as default gateway for each network interface.
Assuming this networking enviroment
Add new routing tables in /etc/iproute2/rt_tables
Add routes to those routing tables
Add rules to apply traffic to the routing tables
Set interfaces ready for receiving ARP replies
Checking ping with -I IPADDR
To make this routes persistent following configuration files have to be changed
For network addresses and routes:
For routing rules:
For receiving ARP replies:
For sending ARP:
Note: Refer to /usr/share/doc/kernel-doc-<version>/Documentation/networking/ip-sysctl.txt for more information about these setting.
