Remove IPAM Connection in vRO
13170     0
I've got v4.3 of the Infoblox IPAM vRO plugin installed and configured. I want to remove one of the IPAM connections I have showing in the vRO inventory as it is now redundant, but I can't find how to do this.
There doesn't appear to be any delete/remove/uninstall workflows for IPAM connections, only a Create IPAM Connection workflow. You also can't right click on the connection in the inventory and run any workflows on it or remove it.
I don't want to have to uninstall andd reinstall the plugin just to remove the connection. Does anyone know of another way to clean this up?
Re: Remove IPAM Connection in vRO
Community Manager
Community Manager
13171     0
IPAM connections are managed in vRealize Automation under Infrastructure –> Endpoints –> Endpoints. You should be able to remove or update the endpoints there.
Tony
13171     0
But this does not remove it from vRO completely. It is still trying to update using the deleted one.
13171     0
How can I edit the current IPAM plugin connection (or add a new connection to IPAM plugin connection) in vRO 7.1? There is no option to edit it even in vco-controlcenter! In vRO itself, when selecting configuration -> edit then i can edit/delete/add new IPAM connection. But my IPAM server is not reachable! The following is quite useful step by step guide, however i could not find an answer to my question in it as I am using IPAM Plugin 3.2.1 rather than 4!
Community Manager
Community Manager
13171     0
The IPAM endpoint connection is stored in the vRO cache. Restarting vRO should clear up any stale entries from the cache.
Tony
13171     0
I don't have IPAM 3.2.1/4.0.0 environment to check but looking at IPAM Plug-in User Guide, it seems in version 3.2.1 the configuration is done via vRO Legacy Configuration application which is not available anymore in vRO 7.1 and newer.
13171     0
I can create XaaS Blueprints so connecting to vRO is not an issue liteblue usps gov.
Not applicable
13171     0
Hey,
Actually i have to reset the password of infoblox endpoint. So my concern is if i update the creds of  infoblox endpoint from vRA , so i have to update parallelly in vRO-infoblox integrations or it should automatically update in vRO once i update infoblox endpoint in vRA.
Please reach me if you have any query.
thanks,
siddhant
