Need to get Lease Time configured for all DHCP Scopes from my Infoblox Grids
951     0
May I know how to pull a report to get Lease Time configured for all DHCP Scopes from my Infoblox Grids
Re: Need to get Lease Time configured for all DHCP Scopes from my Infoblox Grids
952     0
I also need this same information. I have 135 pages of DHCP scope and some were configured with 1 hour leases and need to be changed to 1 day.  Can't find a report that shows the lease time at all.
952     0
In IPAM home toggle from hierarchical view to flat view and export data in cvs import format. Open in excel and the column lease_time will have the configured value in seconds. An empty value means it has inherited the value.Screenshot 2024-01-08 123631.pngScreenshot 2024-01-08 123801.png
