Reporting DNS Statistics per Zone No results found
2257     0
Reporting DNS Statistics per Zone is showing :
No results found
Like on the page 16:
https://www.infoblox.com/wp-content/uploads/2014/08/infoblox-datasheet-trinzic-reporting-sample-repo...
There is no information about any other configuration there, however I'm getting the error:
No results found;
Infoblox version 8.6
Re: Reporting DNS Statistics per Zone No results found
2258     0
The issue was solved after enable the option under Infoblox Grid Reporting properties:
DDI Utilization
2258     0
Hi rafafilho111,
Can you provide the screenshot of where the enable option is?
2258     0
2258     0
Go to the Grid Manager => Reporting => Reporting Properties => DDI Utilization
