DEPLOYMENT GUIDE. INTEGRATION WITH FORESCOUT
Hi there,
The integration is straight forward and does not require a lot of time to implement it using the templates and the video attached to this post.
The deployment guide attached to the post contains detailed step-by-step instruction how to do it.
If you have any questions don't hesistate to ask.
BR,
Vadim
Answers
The deployment guide was updated.
Mainly there were some typos.
0 -
Is this integration still being maintained?
0 -
As far as I know. This is not being maintained. I integrated Forescout with Infoblox in April 2023 and ended up with an Infoblox Tech Support case open for a month. In the end, I determined on my own before support could figure the issue out, that the documentaion was missing a critical step.
The step that was missing in the documentation was to add the Extensible Attributes to either a individual DHCP Subnet or to the default network view under Administration/Network Views/ default
What led me to discover the missing step in the documentation was watching a Youtube video: y o u t u b e .c o m /watch?v=pnnm17F-D-A&t=1s titled "Infoblox DDi integration with ForeScout CounterACT" at the 3:50 mark in the video, it shows the need to add the EA's to the network view. Hope this helps.
1 -
Do you have any updated documentation on this Forescout integration? We are using 8.5.1 and this version looks much different then on the one in the video.
0
Categories
- All Categories
- 5.2K Forums
- 468 Security
- 1.2K Asset Visibility
- Ideas Portal
- Webinars & Events
- 298 Resources
- 298 News & Announcements
- Knowledge Base
- Infoblox Blog
- Support Portal
- 8 Members Hub
- 4 Community Support
