INFOBLOX & TENABLE.IO INTEGRATION TEMPLATES AND DEPLOYMENT GUIDE
Infoblox and Tenable.io together help empower actionable insight into your entire infrastructure’s security risks, allowing for you to quickly and accurately identify, investigate, and prioritize vulnerabilities and misconfigurations in your modern IT environment.
Infoblox provides Tenable.io with resources such as IP addresses, Hosts, and potential threats and in exchange Tenable.io gets improved management on assets and the ability to automatically trigger scans when security events occur. The integration with Infoblox and Tenable.io allows for quicker remediation and more insight into the entire network.
In the attached documents you will find the templates for the Tenable.io integration in txt format. The templates are provided “as-is” and should be tested in your lab environment and modified as needed before implementing them into production.
The templates require extensible attributes described in the table below. It is recommended to inherit attributes with the default values from the network view level.
Extensible Attributes |
Description |
Type |
TNBL_IO_Add_by_Hostname |
Defines if a host should be synced with Tenable.io using a hostname. The hostname should be resolvable by Tenable.io. |
List (true, false) |
TNBL_IO_Last_Scan |
Contains a date when an asset was scanned last time by a request from Infoblox |
String |
TNBL_IO_Scan |
Defines if an asset should be scanned if RPZ, ADP or DNS Tunneling events are triggered |
TNBL_IO_Scan_On_Add |
Defines if an asset should be scanned immediately after creation |
TNBL_IO_Scan_Template |
Defines a Tenable.io active scan which should be used for scans initiated by Infoblox. List of possible values should match active scan names on Tenable.io. |
String |
TNBL_IO_Sync |
Defines if an object should be synced with Tenable.io. |
TNBL_IO_Sync_Time |
Contains date/time when the object was synchronized. |
String |
TNBL_IO_Target_Group |
Defines a target group in Tenable.io that holds the assets to be scanned by Tenable.io. |
String |
Categories
- All Categories
- 5.2K Forums
- 468 Security
- 1.2K Asset Visibility
- Ideas Portal
- Webinars & Events
- 298 Resources
- 298 News & Announcements
- Knowledge Base
- Infoblox Blog
- Support Portal
- 8 Members Hub
- 4 Community Support
