The combined power of Infoblox and Tufin working together helps empower actionable insight into the entire infrastructure, discovering security risks quicker and more accurately and investigating and ranking security policies, all while improving on the organization’s security and compliance.
Infoblox provides Tufin with resources such as networks and potential threats and, in exchange, Tufin gets improved management on networks and security risks, including the ability to create policies and keep companies within compliance with the data received through Infoblox. The integration with Infoblox and Tufin allows faster policy management and more insight into the entire network.
Tufin offers Infoblox networks improved management on the Infoblox DDI and keeps Infoblox within the compliance with policies set by the organization through Tufin. Tufin can add networks to any network view inside Infoblox, allowing further control of the network structure and policies from a single hub on Tufin.
Don’t forget to check out the Video for deploying and using the Tufin integration:
The templates require extensible attributes described in the table below. It is recommended to inherit attributes with the default values from the network view level.
Extensible Attributes
Type
Tufin_Last_Incident
Contains the last date and time when an asset had an incident sent from Infoblox
String
Tufin_Send_Incident
Defines if an asset should send an incident if RPZ, ADP or DNS Tunneling events occur
List
(true, false)
Tufin_Sync
Defines if a network should be synced with Tufin.
List
(true, false)
Tufin_SyncTime
Contains date/time when the network was synchronized.
String
Tufin_Zone
Defines a List of possible Tufin zones to push networks from Infoblox.
List
(Tufin Zone)
Tufin_Sync_Zones
Defines a List of possible Tufin zones to be synced to an Infoblox Network View.
List
(Tufin Zones)
In the attached documents you will find the templates for the Tufin integration in txt format. The templates are provided “as-is” and should be tested in your lab environment and modified as needed before implementing them into production. Here you will find the link to the deployment guide for the Tufin integrations: https://www.infoblox.com/resources/deployment-guides/integration-with-tufin
Here is the Solution Note: https://www.infoblox.com/resources/solution-notes/simplifying-the-management-network-security-zone-policy-with-infoblox-tufin
