Difference between a locked zone and a disabled zone
Hi all,
What is differences between a locked zone and a disabled zone?
0
Answers
Hi Val,
Locking a zone is to prevent someone else can do chages to the zone while it is locked. The zone is still serving via DNS while it is locked.
A disabled zone does not serve via DNS anymore. You would typically disable a zone that is no longer needed prior to deleting it. If it appears the zone should still be in service you can simply re-enable it again.
Kind regards,
Erik
0 -
Ok, I see it more clearly now!
Thank you Erik0
Categories
- All Categories
- 5.2K Forums
- 468 Security
- 1.2K Asset Visibility
- Ideas Portal
- Webinars & Events
- 298 Resources
- 298 News & Announcements
- Knowledge Base
- Infoblox Blog
- Support Portal
- 8 Members Hub
- 4 Community Support
