Hi Infoblox Community,
I’m currently integrating Infoblox with Morpheus Data and facing issues getting both DNS and DHCP to work properly.
🔧 What I’ve Done So Far:
- Integrated Infoblox in Morpheus using the WAPI endpoint
- DNS records are successfully created when I provision VMs from Morpheus
- Configured the network:
192.168.3.0/24 - Created a DHCP range:
192.168.3.100 – 192.168.3.200 - Morpheus uses Static IP mode currently, but I plan to switch to DHCP
🚨 Issue:
When I try to assign a Grid Member to the DHCP range in Infoblox, I get the message:
“There are no objects to select” under the "Delegated To" field.
This prevents DHCP from functioning, and no leases are issued even though several VMs have been created.
🙏 Request:
Can someone guide me on:
- How to properly enable DHCP on a Grid Member so it can be assigned?
- Is there anything else I need to configure for full Morpheus + Infoblox DHCP support?
Any help or step-by-step instructions would be appreciated. Thank you!
integration on morphues,
