Help Needed: Infoblox Integration with Morpheus Data for Full DDI (DNS, DHCP, IPAM) Automation Durin
i Infoblox Community,
I’m working on integrating Infoblox with Morpheus Data and need help achieving full DDI automation — specifically, I want all new VMs provisioned from Morpheus to:
- Automatically get an IP from Infoblox IPAM
- Have a DNS record created in Infoblox
- Get the IP assigned via Infoblox DHCP
🔧 What I’ve Done So Far:
- Configured Infoblox integration in Morpheus using the API (WAPI v2.13.1)
- DNS records are being successfully created
- A DHCP range is defined in Infoblox (
192.168.3.100 – 192.168.3.200) - IPAM Pool in Morpheus is set to use Infoblox (
Static IPmode initially)
🚧 The Problems I'm Facing:
- DHCP leases are not being issued — IPs are getting statically assigned only
- “There are no objects to select”
- So I can't assign a Grid Member to serve DHCP
- DHCP utilization stays at 0%, even after provisioning multiple VMs
🙏 What I Need Help With:
- How do I properly enable DHCP on the Grid Member so it shows up in “Delegated To”?
- What are the required steps in Morpheus to switch from static IP reservation to full DHCP-based provisioning?
- Is there a step-by-step guide or best practices document for full DDI integration between Infoblox and Morpheus?
Any advice, guidance, or experience shared would be greatly appreciated. I want to make sure every VM gets its IP via Infoblox DHCP with corresponding DNS and IPAM entries — fully automated.
Thanks in advance!
Answers
Is Morpheus the HPE stuff? A hypervisor? Not all hypervisors are supported depending on their RFC compliance… and many hybrid cloud environments don't allow DHCP in their VMs. Typically, even for VMWare VRA and VRO there is a dedicated IPAM plugin that is built for this purpose. You can raise an IFR with your account team to get it supported / planned, but if you don't have access to the Morpheus SDK it will prove challenging to get this working if I had to guess.
0
Categories
- All Categories
- 5.2K Forums
- 468 Security
- 1.2K Asset Visibility
- Ideas Portal
- Webinars & Events
- 297 Resources
- 297 News & Announcements
- Knowledge Base
- Infoblox Blog
- Support Portal
- 8 Members Hub
- 4 Community Support
