Hi everyone,
Im trying to set up a GM in HA mode using two Infoblox VM on the same subnet, but I'm running into an issue and would appreciate your guidance.
my setup:
VM1 : IP 1.1.1.2/24 GW 1.1.1.1
VM2: IP 1.1.1.3/24 GW 1.1.1.1
I connect to VM1 and began configuring it (Grid setup Wizard ) Confgure a Grid Master Name,Shared Secret Hostname, Grid master an HA pair: Yes > VRID
Vip 1.1.1.4
Node1 HA: 1.1.1.5
Node2 HA: 1.1.1.5
LAN1 1.1.1.2
LAN2 1.1.1.3
After completing the configuration and running set membership, I lost connectivity to Node1. Ican no longer reach it via its previos IP 1.1.1.2 or via the new VIP 1.1.1.4. the acces via SSH to 1.1.1.2 work
Any help or insights from those experienced with HA GM setups Would be greatly appreciated.
Thanks
