Hello everyone ,
I am beginner in the construction of BOM regarding Infoblox products .
Can you help me with a BOM for 4 hardware appliances TE-1405 . The RQPS is 67K minimum .
Over 3 years .
Thanks
You will need to provide more context.
TE-1405 hardware has been end of sale for over a year and goes end of life in April 2026.
You say you need a BOM but then provide a BOM.
What Cache Hit Ratio do you expect. Is the DNS server logging queries? Are you using RPZ and/or DTC?
Will the servers be authoritative?
The BoM is an output of the correct architecture design. Where is the design?
I recommend reaching out to your aligned solutions architect at Infoblox for a discussion.
Hello @bstafford ,
The DNS will be in recusrsive mode , which means it is an outbound flow for internal users . I see no reason for RPZ details .
As Ben mentioned, the X5 series are no longer available for sale. There is no TE-1405. That's not a valid model number for the Trinzic hardware or software. There are many more details needed to assist you and get you to a currently available SKU that will meet your needs. Do you need assistance identifying your aligned Solutions Architect at Infoblox? If so, drop me a DM and I'll put you in contact with the correct person to assist you with your request.
