howdy,
i have figured out how to write a script to upgrade a single 3750 switch, but i have stacked switches as well and am looking for a script to upgrade x# of switches in the stack with a new IOS using NetMRI simultaneously.
The "IOS Image Upgrade" hacked pretty well although I didn't use it for any stacks. Can you share your code?
this is what worked.
copy flash:c3750e-universalk9-mz.152-4.E4.bin flash2: \rcopy flash:c3750e-universalk9-mz.152-4.E4.bin flash3: \r
delete flash:c3750e-universalk9-mz.152-4.E5.bin \r\rydelete flash2:c3750e-universalk9-mz.152-4.E5.bin \r\rydelete flash3:c3750e-universalk9-mz.152-4.E5.bin \r\ry\rcopy http://10.2.16.11:26/tftp/3750/c3750e-universalk9-mz.152-4.E4.bin flash: \rcopy flash:c3750e-universalk9-mz.152-4.E4.bin flash2: \rcopy flash:c3750e-universalk9-mz.152-4.E4.bin flash3: \rconfig termno boot systemboot system switch all flash:c3750e-universalk9-mz.152-4.E4.bin \rendwrite memory \rreload \r\r
the issue i am working now is that i want to use this script for all 3750 stacked and non stacked switches. but if the switch does not have 3 or 2 switches in the stack the task will error out and fail. i guess what i need is something that will see the error and move on to the next step.
recently discoverd that using a .tar file solves my issue here. you just have to use the archive download-sw command to make it all happen, the switch will load the new IOS on all the switches in the stack automatically.
