Hey guys,
A customer of ours needed a dashboard that gives you the option to show all DHCP Networks that are not being utilized. It's a bit surprising to us that this is not a feature available in any of the default dashboards/reports.
In the default settings you will get all DHCP networks that have no utilization in the last 30 days. This allows a customer to clean up old non used DHCP ranges in big network environments.
John Neerdael & Roy Wiss
SecureLink Netherlands
<form> <label>DHCPv4 Range Utilization - Empty Ranges</label> <description>DHCPv4 Range Utilization - Empty Ranges</description> <fieldset submitButton="true" autoRun="true"> <input type="time" token="time"> <label>Time</label> <default> <earliest>-30d@d</earliest> <latest>now</latest> </default> </input> <input type="text" token="network"> <label>Network (eg: *.168.1.*)</label> <default>*</default> <change> <condition value="All"> <set token="network_str">| noop</set> </condition> <condition value="*"> <set token="network_str">| filterdhcprangesreport start_address end_address "$value$"</set> </condition> </change> <initialValue>*</initialValue> </input> <input type="text" token="dhcp_utilization"> <label>Utilization % (eg: >10)</label> <default>=0.000000</default> <initialValue>=0.000000</initialValue> </input> <input type="text" token="ranges_field"> <label>Ranges (eg: !=0 )</label> <default>!=0</default> <initialValue>!=0</initialValue> </input> </fieldset> <search id="base_search"> <query>index=ib_dhcp_summary report=si_dhcp_range_utilization_trend $dhcp_range_str$ | msservers ms_servers $microsoft_servers_str$ | eval members=if(isnull(members), "", members) $members$ | eval ms_servers=if(isnull(ms_servers), "", ms_servers) | stats avg(dhcp_utilization) as ADU by _time view members ms_servers start_address end_address DHCP_RANGE dhcp_utilization_status $network_str$ | timechart bins=1000 eval(avg(ADU)/10) by DHCP_RANGE where min in bottom$bottomn$ useother=f | interpolate 43200</query> <earliest>$time.earliest$</earliest> <latest>$time.latest$</latest> </search> <row> <panel> <table> <search> <query>sourcetype=ib:dhcp:network index=ib_dhcp (members="*") cidr >=1 address=$network$ ranges$ranges_field$ | stats avg(dhcp_utilization) as ADU by address, cidr, ranges | where ADU $dhcp_utilization$ | sort + address | table address , cidr, ADU, ranges |rename address as Network, cidr as CIDR, ADU as "DHCPv4 Utilization %", ranges as Ranges</query> <earliest>$time.earliest$</earliest> <latest>$time.latest$</latest> </search> <option name="wrap">true</option> <option name="rowNumbers">false</option> <option name="dataOverlayMode">none</option> <option name="drilldown">cell</option> <option name="count">10</option> </table> </panel> </row></form>
