Summary:
On March 16, 2022 ISC announced a new security issue encountered in BIND 9.18.0 as CVE-2022-0396.
Overview:
ISC recently discovered an issue in BIND that allows TCP connection slots to be consumed for an indefinite time frame via a specifically crafted TCP stream sent from a client. This issue is present in BIND 9.16.11 to 9.16.26 (including S editions), and 9.18.0.
This issue can only be triggered on BIND servers which have keep-response-order enabled, which is not the default configuration. The keep-response-order option is an ACL block, and as such, any hosts specified within it will be able to trigger this issue on affected versions.
Impact:
Specifically crafted TCP streams can cause connections to BIND to remain in CLOSE_WAIT status for an indefinite period of time, even after the client has terminated the connection.
CVSS Score: 4.9
CVSS Vector: CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L/E:F/RL
/RC:C
For more information on the Common Vulnerability Scoring System and to obtain your specific environmental score please visit: https://nvd.nist.gov/vuln-metrics/cvss/v3-calculator?vector=AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L/E:F/RL
/RC:C&version=3.1.
